What the heck is this?
So Im doing the dreaded motor mount change and ordering the mounts and I cant find this thing.
It looks like a vibration damper or something? Whatever it is its wasted and needs changing. Anyone have a name for it? |
Year Pacifica? Engine??
Opps sorry that would help huh? 2007 pacifica touring with the 4.0 engine. It is bolted to the back of the rear motor mount. It doesnt go to anything just has weights bolted through the middle of it.
The old Damper Mass, Chrysler PN 04880417AA. Found only on the 2007-08 models....:)
https://www.factorychryslerparts.com...4880417AA.html |
Dang expensive little bugger. Thanks for the info It might have to stay just like it is, Lol
Well it was a good idea to change the motor mounts.
https://cimg7.ibsrv.net/gimg/www.chr...dfb9dba205.jpg |
Damper mass
Originally Posted by djetelina
(Post 105210)
These things are added to reduce body shake. It is a heavy weight in a spring-loaded container with damping fluid. It works by causing the weight within to vibrate at the natural frequency of the structure of the vehicle. The weight winds up vibrating in the opposite direction of body movement, thus exerting a force opposite to the body shake and counteracting it. Got that? The idea is to smooth out vibrations and improve the ride of the car. Can you drive your car without it? Yes, but you may notice an increased level of vibration in the ride.
(Post 121953)
