WHISTLE
I was wondering if anyone has had a problem with there 04 pac whistleing on a cold start up, or even driv'n it cold? PLEASE ANYONE talk to me
RE: WHISTLE
My 05 does for about 10 seconds. I'm not going to worry about it till it's constant. Probably some pully with not enough grease in the bearing.
RE: WHISTLE
What kind of whisle do you have? Is it from the engine area or from inside the car,under the car?
RE: WHISTLE
I have tsbs for Ticking and belt chirp but not a whistle
RE: WHISTLE
It's more of a sound like a low spoil of asupercharger and yes it last for about 10 sec.,but since its got warmer outside, I havent heard it.
RE: WHISTLE
On my last car this would happen when it was very cold and I tend to believe its the oil not getting up to the engine because its so thick. It usually lasted a few seconds and would stop once the oil warmed up and started circulating.
Hi Kevin,
I have been fighting the "Pacifica whistler" issue on my serpentine belt drive. You said that you had the TSB for fixing this...could you send me a copy? If so, my email address is christopherirish@yahoo.com Thanks, Chris - Lynchburg VA |
need year make and model for your car.
RE: Whistling on Pacifica belt
(Post 57195)
dont see anything for an 04
