Wiring Diagram
Old Jan 9, 2023 | 05:05 AM
RSDADDY141's Avatar
Default Wiring Diagram
Good Morning! Does anyone have or know of a free wiring diagram for a 2008 4.0 Limited? Much appreciated!
Old Oct 14, 2023 | 02:29 PM
MrSzuwarowy's Avatar
I have some (a lot of) wiring diagrams. Let me know if You still need it.
Old Nov 29, 2024 | 02:51 PM
ffoltyn's Avatar
Do you have one for the 2023 Pacifica AWD Limited please? I am trying to find out what this item is. Thank you in advance.
Thank you
Old Nov 29, 2024 | 03:53 PM
Why would you need a wire diagram of a car thats 2 years olf max? this would be under a warranty likely
Old Nov 29, 2024 | 04:09 PM
ffoltyn's Avatar
I work for the US military in Germany and if you bring a US car out of the country then warranty doesn't apply.
Old Nov 30, 2024 | 03:05 PM
Understood so whats the issue then ? do you have a scanner that can get into all the modules?
Old Nov 30, 2024 | 04:01 PM
ffoltyn's Avatar
I have a P2AF8 code which I know what the code means but would the dual battery relay cause this code. Also this relay clicks and then sets off the battery light and the A! lights. Does that mean the relay is defective. I replaced and checked the batteries and that isn't the issue.
Thanks in advance.
Frank
Old Nov 30, 2024 | 10:31 PM
Check out the Chrysler diag tree for this
File Type: pdf
Old Dec 1, 2024 | 06:14 AM
ffoltyn's Avatar
Thank you for the printout..I have the one from Alldata which is similar but I hope between the 2 it will point to the issue. With the car driving normal I think it is a ground or wiring issue and not mechanical.
I don't see anything that talks about the Dual ESS battery module though..which is the part that clicks about 5 times and then the lights go on the dash.
do you have access to the T762 schemes that they talk about?
Old Dec 1, 2024 | 08:51 PM
is this a hybrid? whats your vin I can look it up
