-   Chrysler PT Cruiser (https://www.chryslerforum.com/forum/chrysler-pt-cruiser-13/)
-   -   01 pt cruiser windows (https://www.chryslerforum.com/forum/chrysler-pt-cruiser-13/01-pt-cruiser-windows-35083/)
esty Feb 29, 2024 06:54 AM
rear power windows are not locked and don't work at all, ever.... fronts recently started working intermittently...there's no fuse for windows what should i check
esty Feb 29, 2024 10:01 AM
i just discovered that giggling the key in the ignition with car running gets the front windows to work but no back window operation
CHRYSLER TECH Feb 29, 2024 05:25 PM
check for power and ground at the window motors to start
esty Mar 1, 2024 06:47 PM
when windows don't work no power or ground at switch...giggle key, power's at switch
what controls power to windows, there is no fuse...it appears it gets power from ignition switch and i don't have a clue what to check
ggoose Mar 2, 2024 09:44 AM
If jiggling the key gets power to the windows it may be the ignition switch (not the key cylinder). There is a single power feed to the ignition switch. Rotating the key will send the power to the various systems. A number of examples, the ACC position will power the radio and wipers, the RUN position will power the radio windows and fuel pump, the START position will power the fuel pump and starter.
The switch can be had for about $25 so it is your call to fire the parts cannon (search for pt cruiser ignition switch). This link shows how to replace the switch.
CHRYSLER TECH Mar 3, 2024 03:04 PM
the power to the switch goes threw a circuit breaker in the fuse box on driver side. that power to there comes from the ign switch that same circuit from the ign switch also controls the blower motor so if the windows and blower motor not working at the same time then likely the ign switch if not look at the fuse box area.
