02 PT Radiator needs replacement
Well, my uncle has an 02 Cruiser, 2.4 I4 (no turbo) and has a crack in his radiator...
what I'm wondering is, if anyone here has much experience with the PT and how tough it is to replace the radiator. I own a 92 Plymouth Sundance, and just recently replaced the radiator on it, but the engine compartment isn't nearly as packed as the Cruiser's any help will be much appreciated! |
RE: 02 PT Radiator needs replacement
if you can get the front grill off and on without damage to the grill or the bolts not being stripped you got it made[8D]
Yeah they jam all that crap in their pretty good definatly use alot of wd-40 it will help and please take your time and dont get pissed you will break something and make it worse i know from exp here.lol
a bit long but here WARNING: DO NOT OPEN THE RADIATOR DRAINCOCK WITH THE SYSTEM HOT AND UNDER PRESSURE BECAUSE SERIOUS BURNS FROM COOLANT CAN OCCUR. NOTE: It is not necessary to discharge the air conditioning system to remove the radiator. [ol][*]Disconnect throttle body air intake hose from air cleaner housing assembly.[*]Remove air cleaner housing assembly.[*]Disconnect negative battery cable. Disconnect positive battery cable.[*]Remove battery and battery tray.[*]Raise vehicle on hoist. NOTE: When the transaxle cooler lines are removed from the rolled-groove type fittings at the cooler and transaxle, damage to the inner wall of hose will occur. To prevent potential leakage, the cooler hoses and clamps must be replaced.[*]Disconnect and cap the automatic transmission cooler hoses, if equipped[*]Drain cooling system[*]Disconnect radiator fan motor electrical connector[*]Disconnect lower radiator hose[*]Remove two fasteners attaching transmission oil cooler to radiator.[*]Remove two lower fasteners attaching radiator fan shroud to radiator[*]Dislodge lower radiator air seal from side radiator air seals[*]Lower vehicle.[*]Remove grille[*]Remove upper radiator support crossmember[*]Remove upper radiator hose from the radiator[*]Remove remaining fasteners attaching radiator fan shroud to radiator[*]Remove radiator fan/shroud assembly.[*]Remove remaining fasteners attaching AC condenser to radiator. Reposition AC condenser.[*]Remove radiator assembly by lifting it up from the engine compartment. Care should be taken not to damage the cooling fins and tubes during removal.[/b][*]Remove the lower air seal from radiator[/ol] |
