Morganlaurae |
05-15-2019 04:55 PM |
2005 PT cruiser cranks no start
The car died suddenly but still had power while driving. By that I mean everthing such as radio and lights worked. No sputtering or pinging or error lights at the time. The only code showing was the p0522. Replaced the oil sensor switch and a new battery but the car only cranks does not start. Only code still popping up is the p0522. I can see the gears turning at the timing belt. All fuses test okay (tested by moving all fuses and relays to things could check such as horn and lights as had no tester). Had a oil change 2 and half months before this happened as had just bought the car. What could ve causing this? I can hear the fuel pump humming when turning the key and can smell gas in the engine after attempting to start. Thanks
