2005 PT Cruiser GT convertible pump o-ring leak
Old Aug 9, 2023 | 02:19 PM
Mattr3687's Avatar
Default 2005 PT Cruiser GT convertible pump o-ring leak
I have 2 PT Cruiser GT Convertibles, both lose hydraulic pressure. It seems to leak from the top left (driverside) hydraulic line. The o-rings seem to be dry/cracked. Anyone know what size these o-rings are? I've drilled a hole in the plastic holding tank and plugged it with a rubber plug for easy filling. Now I just need to fix the leak.
Old Feb 2, 2025 | 03:14 PM
Prowler6b's Avatar
Default Did you find out the O-ring size?
Hi
hope you can provide some help from your experience. Did you find out the o-ring size. I here is no specific information on the type of oil in the owners manual. Do you know what is best? Did drill a hole in the plastic and plugging work out well with no leaks? I assume the reservoir is not under pressure, correct?
thanks so much for any help anyone can provide!
Timo13
Sep 12, 2020 04:35 PM
helpme1
Aug 20, 2018 08:52 PM
debbie210363
Jan 25, 2007 10:57 AM
mikem
Jul 17, 2006 08:47 PM
