2007 PT. Radiator Fan
Radiator fan will not run at low speed or high. The vehicle has a TIPM so no individual relays. At switch there is power at pin 1 and nothing at pin 2 or 4 for HS and LS. Don't want to just through parts at it plus TIPM is expensive and I do not know how to set it up for my vehicle if this is the issue. Does the car need to be running to test HS and LS going to try that tomorrow.
1) change your font color back to default. :D
2) there's a pair of relays on the fan shroud itself. 3) there's a bulkhead connector usually at the bottom of the shroud as well, that connects those relays back to power and TIPM. 4) where in NJ are you :D |
working on it today...I am in Salem County, are you in NJ?
aye, but you're in the deep south NJ. :D
yup right on the salem river and it feels like the deep south with all of the farm land... I grew up in camden county
i'm "north" jersey :D
| All times are GMT -5. The time now is 05:48 AM. |
