kdm3170 |
01-18-2012 01:31 AM |
from the sounds of it pressure built up inside the tank and the vapor purge device/solenoid isnt being activated. the pressure stuck inside the tank closed the check valve at the bottom of the filler tube preventing gas from being added and making the gas pump shut off. pressure can b relieved by triggering the purge device/solenoid (if it hasnt failed, and i dont know how to trigger it) or by leaving the gas cap off long enuff for the pressure to escape thru the recirculation tube
