2008 Pt cruiser compression test
I need help with a compression test, couldnt find the fuel pump relay to dissable the pump so I can do the compression test, I saw searching online that there is no relay so in this case how to dissable the fuel pump, any help will be apreciated, thanks
with a tipm system prob won't be a relay take the fuse out for the asd
Do you know where the asd fuse is located?
nope will need your owners manual to pin point that fuse
