2008 pt iat sensor
I have 2008 pt trying to find out were the iat sensor is located on the intake tubing.There is a 2 wire sensor midway between the air filter box and the maf,then there is a 3 wire sensor scewed to the maf. Is the iat part of the maf or is the 2 wire sensor the iat? I would apperciate any help you could give me,thanks.
IAT is in the big hose between the air cleaner and the throttle body. It jst pops in a hole. There is no Mass Air Flow sensor on Chrysler products except for a few Mistubishi cars from the 90s that were badged as Chrysler products.
I believe you are mistaking it for the throttle body. It has the TPS and the IAC motor mounted to it. |
