Security light stays on while driving
Old 01-27-2019, 05:23 AM
Slackerlad's Avatar
Default Security light stays on while driving
I have a 2006 convertible touring, out of the blue the key fobs stopped working to unlock the car and the security light on the dash stays lit. It had a blown fuse under the hood I thought replacing that would fix the issue but no luck. The car does have an after market remote start would that cause this problem? Any help would be greatly appreciated
Old 01-27-2019, 08:53 AM
Yes, the aftermarket remote could have something to do with it because the remote start needs to be able to bypass the security system to be able to start the car without the key being present. Remote start technology is very well guarded for obvious reasons, so you're not going to find a simple fix on the internet. You could try disconnecting the battery, shorting the positive cable to the negative cable (NOT shorting the battery!) to drain any residual voltage in the car and see if that resets the computer. If that doesn't do it, you may have to take it back to the shop that installed the remote starter.
Cxckram
01-30-2020 04:37 PM
alan8228
11-08-2019 12:03 PM
JoeR
03-12-2011 01:58 PM
rwburbage
06-25-2010 09:45 PM
dwnhillracer15
04-27-2007 04:30 AM
Quick Reply: Security light stays on while driving
