REBEL59 |
01-28-2018 02:54 PM |
Could be a bad fuel injector on #4, or a problem with the valvetrain for same cylinder. Do a compression test, if #4 is lower than the other 3 cylinders, you are looking at some head work to be done. If OK, and you are getting rich running and gas dilution in the oil, or no spray at all,an injector problem. Wet or dark porcelain tip at the electrode, or totally white and looking like brand new would denote where the trouble lies.
Also did you stay with the factory recommended plus?
