Chrysler PT CruiserOffering a sedan and 2 door convertible, both of which offer a naturally aspirated or turbocharged engine, this car has something to offer everyone
Hi igot 2 problems.
1. the engine fan not working when i turning on the A/c, what make the a/c stop working.
2. the window wiper are working and stops and sometimes continuously. But it works intermittently. i change the wiper engine but the problem still not solved.
i read in some israeli forums that the problem could be in the electronic board of the fuse box.
fan not working is probably the fan being bad. it has 2 windings, one can go and the other will work.
replacing the fan and relays as a module is pretty easy.
could use a bit more details on the wiper problem; your description was unclear.
more than likely then, you have a fault with the A/C and not the fan. the fan doesn't turn on unless the compressor does.
check your wiring from the high pressure switch to the low pressure switch for continuity, then check the other low pressure wire for connection to ground,
