Chrysler PT Cruiser 2007 stop running suddenly
Hello My PT Cruiser 2007 was running and stopped by itself, and never more started (2 months ago), i replaced new brand the MAP and MAF sensors, cleaned the acceleration module, i replaced for a brand new ignition coil, and 4 brand new spark plugs , and nothing, finally i knew about the ASD relays, that feed the power to the ignition coil, spark plugs , fuel pump and injectors, in this case i detected that the ASD fuses are 26 and 23 , and ASD relay are the 32 and 18, where only i have power is in the 18 relay, the others has no power in the fuse and relay connectors pins. Can someone help me with this issue? can be a bad fuse box and PCM module too?? Please any help
