chrysler radio p05064173af wiring on a 06 PT Cruiser
Help! I have a 06 PT Cruiser and I'm trying to install a new stereo but the stereo wiring is different than the adapter plug I bought. I went online to find the wiring diagram for my stock stereo. I found diagrams for dozens of Chrysler radios but none for mine. I have a Chrysler radio p05064173af. It has 2 plugs. A small 10 pin and a large 22 pin side by side. the small plug has 3 wires, a green/yellow in pin 1, a gray/red in pin 2 and a green/red in pin 6. The large plug is the same as all the others I looked at except instead of pins 2 & 13 having the accessory and lighting wires pins 2,3,4 and 5 are empty as are pins 13-16. what I do have is a white/red wire in pin 6 and a solid white wire in pin 7. I tested all wires with the acc switch on and except for the bat+ wires in pins 1 & 12 and the white/red wire in pin 6 were cold. The white/red wire in pin 6 set off warning ding and digital boxes formed around the gear indicators on the speedometer. Can anyone tell me where to hook up the accessory and lighting wires on my new stereo?
