Crank no start
2001 PT cruiser 2.4l non turbo has spark,fuel,timing, and compression I've also replaced the crank sensor but it won't start it cranks and if I crank it and have it at full throttle it tries but never start. Please help she's my only daily and can't afford a new one right now
spray brake cleaner or starting fluid into the throttle body does it attempt to start ?
(Post 121680)
get a spark tester from about any store put i inline to the coil wires see if it flashes when starting.
(Post 121686)
codes in the computer?
(Post 121690)
only need 3 things spark fuel and air so haft to be missing one of them noid light on the injectors it is shooting fuel?
How many miles? Has the timing belt ever been changed?
You noted compression, how was this determined? Were readings taken on each of the cylinders and what were the numbers? |
Originally Posted by ggoose
(Post 121696)
