pgp1999 |
05-06-2019 07:34 PM |
p0700 and p0882 06 PT
i have an 06 pt and my trans recently got put in limp so it won't shift. i have a check engine light with p0700 and p0882. i saw im supposed to check the t15 circuit with a meter but im a little confused. to test circuit t15 with the p0700 and p0882 dtc codes, i need to remove connector #4 at the pcm and then remove connector #2 at the tipm, but i'm not exactly sure which one is connector 2 since they are labeled a, b, c, etc. in the tipm. which one is #2. if i don't have any continuity between c4 #18 and c2 #10 what has that indicated? is there a procedure to test for a bad relay in the tipm? sorry for all the ?s also i saw that the yellow/brown #2 wire from the tipm goes to an intermediate connector c102 and exits c102 as a light green wire and goes to connector #4 at the pcm, but where is this c102 intermediate connector located? i can't see where the light green wire is. thanks for replies - pete
