-   Chrysler PT Cruiser (https://www.chryslerforum.com/forum/chrysler-pt-cruiser-13/)
-   -   Pt cruiser limited 2007 2.4 (https://www.chryslerforum.com/forum/chrysler-pt-cruiser-13/pt-cruiser-limited-2007-2-4-a-35756/)
ldoni123 Aug 29, 2025 12:44 PM
Hi
I got a problem with charging that I can't fix.
The battery light on the dash are on, the charging is not good. Between 10.8 to 14.1.
I already changed 2 alternators and chabge the battery. I tried everything i checked the cables, there not fuse for the alternator there a tpim.
someone got idea ?
ggoose Aug 30, 2025 10:02 AM
Suggest inspecting and cleaning the 2 ground points on the driver side strut tower. They should be disassembled and cleaned. These ground points are known to corrode without an outward visible indication.
Another possibility is a failing PCM. Unfortunately the heat buildup in the engine compartment and the PCM location can cause the PCM to 'cook' and slowly fail. Note the charging voltage is regulated by the PCM. Replacing the PCM should be the last resort though.
