PT dies
A co-worker has 2003 PT with manual trans. When they come to a stop it will die and also when slowing down to make a turn. It doesn't do it when the A/C is on. It does it when the clutch is pushed in. What is going on here?
Thanks for any help Jerry |
The throttle body is probably filthy. IAC motor may be slow to move also. WHen the AC is on, you will get a larger pulse with from the PCM to the IAC in order to idle up the RPMs due to the drag from AC on the engine.
