00' intake leak
Hi all,
I have a 2000 T&C with a 3.3 flex fuel. the intake gasket is leaking antifreeze and I'm planning on replacing. going to do valve cover gaskets, T-stat and spark plugs while it's apart. I was wondering if there is a way to determine which valve cover gaskets I need without taking it apart. And if anybody has any other tips or tricks to make this job go as smooth as possible. Thanks in Advance Josh |
U will just need to see if U have the thick gaskets or the thin ones only u can tell
So your saying I need to remove a valve cover to find out? That kind of sucks was hoping to make 1 parts run before tearing it apart and want to know if local parts houses have parts so I dont have to leave it tore down and inoperable.
