-   Chrysler Voyager & Town & Country (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/)
-   -   '01 T&C squeaking sound when I turn the wheel. Is that coming from the rack or the steering wheel? (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/01-t-c-squeaking-sound-when-i-turn-wheel-coming-rack-steering-wheel-4029/)
tk1780 Oct 25, 2007 10:52 AM
Is there any place to lubricate the steering wheel?
I changed the resevoir and put in synthetic fluid.
moe Oct 25, 2007 11:00 AM
RE: '01 T&C squeaking sound when I turn the wheel. Is that coming from the rack or the steering wheel?
is the noise coming from inside of the car.?if so you might get away with lubing the boot at the base of the steering column.need more info.moe
tk1780 Oct 25, 2007 02:47 PM
It's hard to tell where it is coming from, in or out
moe Oct 25, 2007 04:17 PM
i know they had issues with power steering lines under the car.and an issue with the power steering hose itself,but that was for a different noise that you discribe. maybe truck tech or chry tech might know of something. sorry moe :( i don't know
truck tech Oct 25, 2007 06:06 PM
Hello, sounds like a dry outer tie rod end, or lower balljoint. There is a easy way to check. Go to your local parts store and get a needle grease adpt. for your grease gun.Stick itinto thegrease boot and pump in some grease. turn it back and forth and the drive it and see if the noise is gone. Noises travalin vech. so its hard to say. Good luck. God Bless!!
tk1780 Oct 26, 2007 08:17 AM
it sounds like gym shoes on a wet floor
moe Oct 26, 2007 08:32 AM
sure your belt is not slipping?
master tech Oct 26, 2007 11:34 PM
You could have a dry boot at the lower steering coupler or a fan belt tensioner that is frozen or even ball joints or tie rod ends. Some how you need to isolate the sound/ noise.
F150 Oct 27, 2007 04:21 AM
My 2001 T&C Limited does the same thing but it's only in the garage on the smooth concrete, Outside on a rougher surface it's quiet.
tk1780 Oct 30, 2007 10:39 AM
It only happens when I turn the steering wheel, so
that is why I think it is the steering and not the belt or tensioner.
Could it come from the rack?
