02 Chrysler T/C Transmission Leak
I have a Chrysler 02 T/C the outside temperature was 29 degrees and the cold weather lasted for about 4 days in Florida that is cold but my question is I noticed 2 oil spots on the driveway and found it was coming from the transmission pan could this cold weather have effected the pan gasket should I have it replaced or will the warm weather swell the seal back to normal I guess this is wishful thinking mileage is not ready for a fluid change yet. |
RE: 02 Chrysler T/C Transmission Leak
have u done service to the tranny yet??? an 02 u should have 2 times already 30k each. Trannt fluid is still an oil based oil like engine oil it will break down over time . The pan is sealed up with ATF RTV
Yes I did 2 fluid changes. I had a Dodge Caravan that did the same thing in cold weather and did not solve the issue and the leak would go away in hot or warm weather.
