'02 T&C Power Sliding Door needs Clutch Motor?
Hi everyone,
The passenger power sliding door on my '02 T&C LXi opens fine, but when I try to electronically close it I here a click and the motor doesn't turn on. If I pull the handle at the same time as the click and "help" the door a bit, the motor kicks in and the door shuts fine. The dealer told me that I need a new clutch motor. Is there only 1 motor in the door? Or does anyone know what the "clutch motor" is? Here's a picture of a door from a 2001 caravan. Can someone identify the "clutch motor" on here for me? Thanks, beatle78 |
RE: '02 T&C Power Sliding Door needs Clutch Motor?
i could not see the whole pic but it looks like the dcx pic so i will tell ya its number 15 and you may need 16 as welll the cable we install them alot in pairs as i think dcx revamped it and you may need both of them.
Usually that is the problem the motor kinda fails for some reason or another. |
only one motor did they tell u anything about the code they pulled from the PSD module???
I hardly see motors messup more latches then anything. |
