03 T&C 3.8L starting question
I recently replaced my fuel pump and filter while on the road (had to use non-OEM parts - Airtex). After the replacement everything ran/started great. Recently when you attempt to start the engine by just cranking without touching the accelerator it won't start. I now have to press the accelerator to get it to fire up. Idles fine and drives strong. Just curious why all of a sudden I have to give it some gas to get it to fire up. Plugs and wires recently replaced as well (before the Fuel pump and filter). There is less than 500 miles on all of these parts.
Any suggestions as to why?
3.8 L 250K miles
3.8 L 250K miles
I'll try this tonight. I can tell you this though, you can hear the pump momentarily run when you first turn the Key to ON. I would assume it is priming the system.
Because when I had to turn teh key on and off 3x the fuel pump has primed up and fuel is now at teh injectors. IF u wait awhile it will drain back into teh gas tank.
U have a bad fuel pump basically
CHRYSLER TECH,
I had some other things keeping me from replacing the Fuel Pump. Still runs great only you have to prime the pump with the key-bump when it hasn't been running for a while.
If the fuel pump is low on pressure will it cause bad gas mileage? Currently the minivan is getting less than 12 MPG when I have always had around 17 MPG in the city. Not sure what is causing this one, but if the fuel pump could be part of this I see dropping the tank again in my near future. I had to use an AirTex unit at the time so it is under a lifetime warranty, but I might have to just pay again and get a mopar unit. What should the normal operating pressure be if I were to put a fuel pressure gauge on it? Is there a pressure I should look for when the ignition is turned on (primed pressure)?
Thanks,
Thanks,
