04 voyager 2.8L engine loom help
So far I found 1 loom/wire set that connects to the engine. I am 95 percent sure it connects to the ECU. Now does the loom have 2 connectors that connect to the ECU or only one??
q2) does the electric gas petal connect straight to the loom?? q3) doesthe engine loom have connectors to the fusebox and BCM as well or strictly only ECU ?? a diagram will be appreciated if provided. Thank you guys so much in helping in my conversion to diesel. |
The ideal would be to get a diagram picture (seen it somewhere) of the ECU and all the wires attached/going in/out of it. I'm sure there is quite a few sensor wires involved in being attached to the ECU alone.
