'05 T&C No Headlights???
Hello All
I have a '05 T&C that all of a sudden last night the headlights quit working. Now if you use the stalk on the the steering column and hold it the high beams work. I checked fuse panel with no luck. Anyone have thoughts on what could be wrong? Headlight switch? Thanks in Advance. |
Did some other searching via Google and found this thread...
http://forum.chryslerminivan.net/sho...8979#post78979 |
possible fcm or ipm fuse box or front controller
(Post 34807)
I have never had to replace a headlight switch for headlights not coming on.
U can replace it if u want see if it works. |
First thing, check the bulbs. I once had both low beams blow at the same time on my old Concorde. Maybe it was a little voltage surge on old bulbs that did it but it can happen.
(Post 34855)
Check the circuit breaker.
there is not one the front head lights along with the running and brake lights are computer controlled.
