06 Manual Sliding door adjustment
One of the sliding doors needs adjustment, it is basically too far forward and hits the body when closing.
I looked at the mechnism quickly but didn't readily see where it could be adjusted. Appreciate your help. |
You can loosen the bolts which hold the door and shift the door a little before thigtening the bolts again.
Theres some space for adjustment |
Thanks! I didn't see any bolts when I looked, just the hinge for the sliding mech. I'll take a closer look as I am sure they are there.
It's my fault, got pissed one day and slammed the ------- thing.... |
The top edge of the door was hitting the body when closing. The top hinge was a little bent, I removed it, bent it back, about a 1/4 inch, adjusted the door up too by about so now the gap is right, took 3 tries but it's solid now.
