1776 Code ?
Hi all. I've just put an obd reader on and its given a P1776 code
Any ideas my code book goes upto P0999 Thanks Adrian |
A/T Solenoid Switch Latched In Low/Reverse Position
Are you having any shifting problems? Could be a bad solenoid pack but that's a guess. |
Thank you for the reply. No problem with shifting, the only time I've had a problem is if im on a slight gradiant and use P and no hand brake. It can be hard to put into Drive then.
Thanks again Adrian |
