1995 Grand Voyager(mk1)2.5TD Problems
Hi all. Please help me with this van. Just acquire it from a car dealer with the yellow ABS light illuminating and in fact, the system is not working, and the pedal is a little stiffer. Amazingly the, cruise control is working perfectly. I also came to realize recently that the radiator fan is also not working as it should. I tried to connect direct to battery it worked!! I have a feeling of broken relays as a source of my problems and plan to change all of them, will it help? Here in Finland it is very difficult to find English service manuals and in fact even Finnish manuals of the former models like mine. Please if anyone can share me with a kind advice will appreciate.:D
Hi
Check your relays first and power and grounds. Then come back tell me what you are after be it wiring info and so on and I will see what I can get for you. |
Thank you Merlin.I did not have time to do such work so far.Things are difficult here especially with a 2yr old son wish to help!! Will update u later.
relays
Originally Posted by Merlin
(Post 27725)
Hi
Abs light and stiff pedal on a 2002 voyager
Hi my brakes pedal started to get stiff and brakes hardly worked intermitently then the abs light came on . i haven't got a clue any suggestions please
