1997 Plymouth Grand Voyager P/S pump ?
I have a 1997 Plymouth Grand Voyager 3.3L with air that needs the power steering pump replaced. The question is how do you get the old one off in the tight space that there seems to be under the vehicle. Any tips will be much appreciated. I am new to forums and doing my own service to my vehicles.
I got the same problem with the exception of the pulley also came apart after replacing the belt tensioner. Someone hopefully will answer cause help is definitely needed here.
buy a service manual it will walk u through it
You have to move the passenger side drive shaft out of the way to remove the p/s pump. There is no need to buy a manual. Make sure you put a pan under the transmission to catch the transmission fluid.
