1999 T&C randomly dinging
My 99 T&C Lxi that just turned over 90k miles has been having this issue with it dinging randomly. The dinging sound is the same sound that dings when you have the key in the ignition and your door open. The van will start dinging for several minutes either right after you turn the van on or during a drive. It seems to be random. I bought the van used in 2002 and it used to happen once a year. Then it started doing it twice a year... Last year it started doing it for weeks at a time. Disconnecting the battery helped and seemed to stop it from doing for a couple months. Now disconnecting the battery seems to have little effect on it. As I said, it usually happens right after I start the van and put it in gear but also happens just randomly out of no wear on a highway. For example I drove a 60 mile stretch last week and it did it twice during the tip randomly just cruising along. I have looked online but only found one other post with a similar issue but it had no response. Any ideas?
