2.0 poor starting when its wet
Hi,
I've done a search on here but couldn't see a similar post? Our 2.0 Voyager starts perfectly when its dry or cold, even below freezing but when its been raining or is raining it keeps stalling until its got warmed up. I've had a good allround spray with DampStart on the wiring and leads and can't see any signs of tracking even when its dark. Anyone got any ideas if there's a bit or a sensor that might be the cause of it? I did wonder if its the IAC valve sticking in the damp? Thanks in advance Paul |
nope.
IAC valve is hardly a problem. you better try some old/used but still OK CAM sensor and then try to start the engine. |
