2.5 crd glow plugs
Hi all
My first diesel car - 2001 Grand Voyager 2.5crd Thought I might be ok with maintenance since I have always done basic maintenance on all my previous petrol cars. So since I have a problem starting the new diesel car in cold weather I thought I would test the glow plugs for resistance, power supply etc. Then I hit my first problem - Where are the glow plugs? Sounds daft and I felt a bit silly - I can find injectors etc but I cannot find the glow plugs! Are they hidden or am I missing the obvious? I have found the associated relay but getting dark outside now so will be testing that on my next day off. Please be patient if I dont reply to your comments but I seem to spend my life at work these days. |
Sorry that last line is meant to read ---
Please be patient if I dont reply to your comments very quickly but I seem to spend my life at work these days. |
Remove the engine cover and they're in front of you. Each with an individual wire (unlike my old vauxhalls that had a strap between them all).
You'll see them fine in daylight. |
Is your engine the 2.5 crd 16v VM?
If so you can find the glow plugs under the intake mainfold. They are not very easy to change... |
You might need to remove the intake elbow to gain access. If the wiring of the 2.5 is the same as the 2.8 then there is a square 4 pin plug on top of the triangular plate above the alternator which is where the glow plug wiring connects to the loom and is a nice easy place to test from.
You should read about 0.4 - 0.6 ohms per plug Regards Richard |
Thanks guys. Found the glow plugs under the intake manifold. I see what you mean when you said awkward to get to! I will need to wait till Sunday now until I get a day off to get to work on them. Till then I just hope the weather doesn't get colder as it is a pig to start in the morning.
Once that is sorted then I got electric window to sort, hand brake doesn't hold very well, one door doesn't lock. Oh also what appears to be a common problem, the thermostat! What an awkward place that is! Well I did get the car cheap! Cosmetically it is in very good condition just the problems as listed and then I should have an a1 car. |
| All times are GMT -5. The time now is 02:00 AM. |
