2.8 CRD Fuel Rail Valve??
Old Jun 22, 2012 | 12:23 PM
joker2cv's Avatar
Default 2.8 CRD Fuel Rail Valve??
I see that on right side of the fuel rail is attached a return hose, like on the top of injectors.
I tried to disconnect that hose while idling and many diesel exit from the fuel rail: is it normal?
I think that this valve should be the for security and only open in case of excessive pressure: is it right or not?
I'd like to know this because i have a P1130 code with engine cutting out in acceleration: if that valve should be closed i found the problem!
Old Aug 25, 2024 | 12:06 PM
cho1sen's Avatar
Hello,
Did that fuel rail pressure relief valve change helped you?
Morten Karlsen
Aug 25, 2024 12:09 PM
thecorvetteben
Dec 9, 2016 09:33 PM
graham payne
Sep 9, 2015 08:00 AM
dstevens49
Oct 3, 2014 09:44 PM
johner07
Jan 29, 2012 10:28 PM
