Turn Signal problem,,,PLEASE HELP!!
I have a 01 town and country that I just replaced the multifunction switch in because i did not have signals or hazards and guess what,,, I still dont! I have checked all the bulbs, fuses and yes I even replaced the BCM thinking that maybe it was the problem. I cleaned the battery terminals so there is no corrosion on the at all. I am not sure where to start next any help would be great, I just want to mention that all other lights work perfectly fine,
there isn't a trailer wire harness, and yes I had to replace the fuel injector wire harness because all the insulation had melted and the wires became one solid mass of wire causing one the injectors to remain open and that's when the problem started
I will definitely give it a try,, right now I will try anything, thank you for the tip I'll let you know if it works.
also just want to mention that the signal flash on the dash like they are working fine but they are not flashing on the outside of the vehicle and I have replace the relay as well and that did absolutely nothing.
Might try disconnecting each light assembly one at a time and see what effect it has. Nothing? Try the instrument cluster then the message center. You may have to check wire continuity from the BCM to each light assembly and from the MF switch to the BCM. Need wire diagrams? Send me an email address to send them to in a private message. How? Click Raptor 07 at left.
swittie
11-10-2020 02:02 PM
SDumitru
09-07-2008 12:34 AM
