2000 Chrysler Voyager Transmission Problem
Ok in the morning this just started happening car starts up fine goes into reverse but when you put it in drive it's like it's in Neutral. has no drive and just rev's I guess you would say this is Limp mode. I let it warm up for a while and then it drives fine.. until the next when it does the same thing it does not shift hard or anything.. Have not checked fluid, just wondering if this is a winter thing?.. or is My transmission about to go. Bought the car in July and it has never showed no problem during shifting but is weak on the big hills. I have had a Solenoid Switch Pack go bad on a 02 Intrepid butit didnt do this and the speedometer works.. any help would be great the check engine light does not come on at all.
RE: 2000 Chrysler Voyager Transmission Problem
i would check your fluid level first,if it ok then i would have to say your seals are hardening,common in cold and hot weather.sounds like it time for overhaul.or let trans warm up.before dropping into gear.moe
2000 chrysler grand voyager
I have a 2000 Chrysler grand voyager and it went into limp mode.. I changed the input and output sensors on the trans. it changed absolutely nothing now I don't know what else to try anyone have any suggestions?????????
the speedometer doesn't work either????? im just about at my witts end with this vehicle can anyone help??
get the codes from the transmission computer should have been the first thing U did
| All times are GMT -5. The time now is 03:12 AM. |
