2000 town & country 3.3 lt
engine light on, transmission slips. checked with a hand held digital diagnostic tool. codes are po7030 gear 4 incorrect ratio and po7032 gear 2 incorrect ratio. also p1781, p1782, p1784 and po700. what do i do now?:confused:
Sounds like you lost fluid pressure in the trans. Was there a code named "Loss Of Prime" Does it makes a whizzing noise while it slips?
no code for loss of prime, it does make a whizzzing sound when it slips.
what needs to be done if loss of prime?
2000 town & country 3.3 L.
code p0734 gear 4 incorrect ratio, p0732 gear 2 incorrect ratio, p1781 pressure switch circuit 0D, p1782 pressure switch circuit 2-4, p1784 pressure switch circuit LR, p0700 transmission control system MIL request.
what do i need to do with this problem ? |
If you don't get an answer here head over to DodgeForum.com or The Chrysler Minivan Fan Club . There are several tranny techs on the forums.
Originally Posted by warmar70
(Post 56168)
where do I check manually the oil pressure on a 3.3 engine in a 2000 Chrysler town & country?
One assumes you've checked for loss of ATF fluid, i.e. correct on the dipstick under conditions as outlined?
Leedsman. |
