2001 Voyager Starter Ground Bolt?
hello, my starter was bad i thought, then i found the ground bolt totally rusted and it actually snapped when i tried removing it. but now i cant seem to find just a ground bolt? is it possible to get just the bolt?
it is the kind that actually goes into the housing and the other end holds the cylinder. i had to put the bolt on minus the plastic housing just to be able to use the vehicle, but now it sparks every time we start it, which is a dangerous situation i would like to remedy. thanks |
Originally Posted by distracto
(Post 32565)
ok in my investigations i have found out it is actually the main battery bolt, or also the solenoid.
and still no luck finding just that bolt either... do i really have to shell out over a hundred bucks for an entire starter because i busted the bolt? |
Oh you mean the power cable to the starter terminal. how the F did you do that? you can get a proper replacement from any starter rebuilder. while your at it, you might as well get new solenoid contacts because they wear out quickly. VERY easy job to fix. do a google search on how to repair a Denso starter.
I'll make it easy on you and do all the searching, I found this on some other web forum... http://www.nationsautoelectric.com/Nippondenso.html |
thanks for the info, though i have looked into that and kinda thought mine was different for some reason... as it seems the terminal (bolt) the battery attaches to (that i broke because it was rusted in place), the other end is the contact that actually holds the plunger in place?
am i wrong? maybe they were just sorta fused together,,, sure seemed like one piece though. |
so far we've wasted 2 days trying to resolve your problem. why don't you take a picture of the problem and post. your headline says ground bolt which is a double ended bolt where one side holds the starter to the trans and the other has a nut for the ground wires. then it seems you're actually talking about the power wire from the battery to the starter. so clarify this problem with a picture... which is worth a 1000 words and saves everyone a lot of wasted time
