2002 Grand Voyager headlight height adjust switch
Another small issue that bothers me in my 2002 voyager is the "height adjust headlight switch"
The switch on the right was broken so I replaced the panel with a new panel from a ram van but the headlights still don't move at all when I try to adjust height. :mad: all other buttons are working well *Is there a fuse for this function anywhere? I cant find it. *any tips to get the lights up and down again? Thx in advance. https://scontent-b-ams.xx.fbcdn.net/...48709487_n.jpg |
1 Attachment(s)
The picture is stolen from internet :) but apart from the icon for front foglights correct.
I checked partnumbers and I replaced the original p0th131l5ac with a p0th131l5ad which seem to be the same items? I checked the headlights and the motors are in place so now I have to figure out how I can check the functionality with the multimeter (and I'm not very used to work with that device :o ) From QinteQ's links I got this On any setting, the resistance between 1 and 2 should be 3191-3400 ohms 0 1 7 3238-3456 1 1 7 1195-1225 2 1 7 746-765 |
Well I checked the Ohm on the control as told in the example and those figures are perfect, but it seems the motors are not running at all do readjusting like the example is not going to work.
My nxt step will be trying to measure if any electricity reaches the little motors when I use the control. So there is no separate fuse for this function as anyone knows off? |
checked the little motor on the left headlight and it started working :cool:
Right one seems dead so I guess all i need to do is replace the motor at the right headlight. |
| All times are GMT -5. The time now is 11:41 PM. |
