2002 T&C Cruise Control comes on automatically
Cruise control turns on/off automatically, causing engine to surge.
The BCM was removed and send to aftermarket repair, but tested OK. The PCM was replaced a few years ago from good internet source, and security key/lock replaced about a year ago with no problems since. What to check next?? |
im told ,speed sensor, vacuum to cruise or computer under dash. I have the same problem. richielap
Have you had a problem with ABS, a simple malfunctioning ABS sensor can knock the cruise system on and off ?
| All times are GMT -5. The time now is 02:19 AM. |
