2002 T&C, a pop noise, then nothing
2002 T&C, 3.3, van was running great, then shut it off for about 3 min., when I went to crank it, there was a electrical pop noise, then nothing. The motor does not turn over, all the gauges with dials peg out, (speedometer, tach, etc) no check engine light, oil light, odometer. the only light on the dash is the door open light. I can hear clicking from the relays, starter, alternator, but the engine does nothing.
Battery is good, I checked fuses, all seems good. Any suggestions?? thanks |
RE: 2002 T&C, a pop noise, then nothing
Battery connections, starter connections? How did you test the battery? Did you try jumping the van?
