2002 T&C Power Steering Issue
Hi All,
I'm hoping to find some info & advice My wife's 2002 T&C has started making a "moaning & groaning"sound in the Power Steering. I took it to a local shop & they said Chrysler recommended that the return hose be changed out with a longer one. They did the work (which DIDN'T solve the problem) and the sound is even louder than before. When the van is driven after sitting fora couple of hours, the sound is barely noticeable, but within 5 minutes the sound is back in full force. A friend told me his father-in-law drained the PS reservoir and refilled it with something (I'm thinking it was somekind of conditioner) & that solved the problem. Anybody have any info or ideas on this? |
RE: 2002 T&C Power Steering Issue
Try replacing the plastic power steering reservoir. There is a non-replaceable filter/screen inside that gets plugged, which starves the pump for fluid.
It only costs about $30 from the dealer.... BTW the power steering fluid of choice is MOPAR ATF+4 |
well my aunt and my grandparents both have a 02 t&c and they both had a problem with power stering and there was something wrong with the power stering pump and there are covered warrenty since it was deffective u could go to ur local dealer and see if there was a recall
To my knowledge there's no recall for this. Most of the T&C's do this. I've done the TSB which involves replacing a hose and putting a loop in it and adding a power steering cooler. I dont think it really did anything but the customer hasn't been back. haven't really heard of a fix for this.
