2002 T&C Radiator Fan relay location
Greetings! Can someone please assist with where the radiator fan relay is for the 2002 Town and Country? I read prior posts with a 1996 and 2001. The 2001 they said was on the frame below the radiator. Is that true for the '02' as well? I started taking the headlights out and some of the front bumper cover, but have not been able to locate the relay or wires with a flashlight. Will continue my search tomorrow. There is some sort of heat sink item on top of the metal bumper, but that does not look like the relay I got from AutoZone.
Any help would be greatly appreciated. Thanks! David |
RE: 2002 T&C Radiator Fan relay location
The radiator fan relay is solid state and is located on the front bumper reinforcment, behind the grill.
1. Open hood and disconnect and isolate the battery negative cable. 2.Remove the radiator crossmember to front fascia closure panel. 3.Disconnect the relay electrical connector.4.Remove the rivet (drill) attaching the relay to the front bumper beam and remove the relay. |
Thanks for the info Magneticred, would this be why MY fans (2002 Limited) come occasionally when not needed? like in the winter or on the highway?
| All times are GMT -5. The time now is 04:06 AM. |
