2002 T&C Transmission Problem
My vehicle is a 2002 Chrysler Town and Country with a 3.3L engine. The vehicle has approximately 130,000 miles on it. I don't know if the transmission oil and filter have ever been changed. Yesterday, with no previous problems, a loud whine started while I was driving at about 45 miles per hour. At first I thought it was an ambulance siren. One mile later, the transmission stopped working as if it were in neutral rather that in drive. I stopped the car, turned it off and restarted. It drove for about a mile and then the whine came back and it stopped working again. There are no permanent codes and the check engine light is off. I hooked a scanner up and there are several pending codes- P0700, P0731, P0733, P0734, P0841 and P0846. The transmission fluid is at the proper level. The transmission does NOT enter the limp mode. What should I look for?
The whine is relevant to the speed of the transmission? the codes are gear ratio errors and pressure switch codes Im gonna say U have a bad front pump which means the trans would need to come out
Yes, the whine changes with the speed of the engine. The whine exists when stopped in drive or stopped and in neutral.
This is a follow-up for the benefit of others to see. I replaced the filter and fluid this evening. Afterwards I drove for about 10 miles and the problem seems to be completely solved.
Your trans filter could be clogged. Try to change oil and filter first of all.
humm this is deff gonna sound like an ass but I cant help it. joker did u by chance read what was posted above your??? Really.
Sorry mate...
its all good lol I have boys at home so I myself hate having to repeat myself like 10 times for the same answer.
Originally Posted by thomascathybell
(Post 69921)
