2002 town and country 3.3 flexfuel no crank.
Over time it seem to start at the very last part when i turned the key. felt the ignition switch was going bad. one morning the van doesnt crank. i go to replace the ignition switch. still does not crank.
I jump the starter relay and the van cranks. starter assumed good. switched relays. same problem. i unplug the pcm and same thing switched batteries nothing red security light is solid. tried different key tried unlocking door with key to shut off security. not sure if its the immobilizer. not sure what to do next |
