2003 Voyager sputtering and backfiring
Hello all,
First of all thanks for your valuable insight on this forum!!! Because of you guys I was able to successfully clear the dreaded "Evap Large leak, Small leak" codes on my 03 voyager 3.3 flex-fuel. I actually found the hose going to the black box on the drivers side had a broken clamp. Once replaced, the code went away after 3 restarts. I am having another problem though and it is not producing any codes. When I begin to accelerate the van sputters and backfires, almost as if it were going to stall. I replaced the plug wires but no effect. Should I go for the plugs next..maybe the EGR valve???? Thanks for your help again. |
RE: 2003 Voyager sputtering and backfiring
Hmmm.. No replies, Shocking!!! I replaced the plugs and the problem went away in case anyone is interested.
r&r plugs
