2004 voyager driveshaft
Hi all , just a quick question, does the trans fluid run out the trans when the driveshafts are pulled out. Jon. 4speed.
Hi
Apparently not, my documentation doesn't say anything about draining transmission before removing drive shaft, but don't hold me to this! It does warn you not to damage the seal with the snap ring on removal. The inner joint is held in by a snap ring, you lever the joint out. hope this helps. |
thanks rodger, have got to replace rear crank oil seals, didnt know weather i was going to get oil everywhere, cant seem to find much info on the 2.8crd auto setup. thanks, Jon.
