-   Chrysler Voyager & Town & Country (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/)
-   -   2005 T&C lightbuld - 3 zone Auto Temp Control (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/2005-t-c-lightbuld-3-zone-auto-temp-control-12485/)
adourov Sep 22, 2010 04:05 PM
2005 Town and Country equipped with the Infrared Three-Zone Automatic Temperature Control. The lightbulb that would light up the right side of the right most dial - feet / feet-defrost / defrost, along with teh recirc rocker switch - has burnt out. How do I replace the bulb?
I was able to remove the entire unit from the dash. There are 4 Torx #15 screws that hold the two pieces together, along with I think 5 pressure clips. Taking out the screws and "jiggling" the pressure clips did not actually get the two pieces apart, yet it seems like the rocker switches on the front start to wiggle.
Thanks !
Alex
moparrh Sep 23, 2010 12:09 PM
Light bulbs
Did you remove the three control knobs? There is one more torque screw on the inside that will have to be removed in order to seperate the circuit board. Disconnect the small wiring connector in the corner. The bulbs are soldered into the circuit board.
adourov Sep 23, 2010 12:19 PM
3 knobs
I have not tried to remove the knobs, but guessing from your reply that they are removable. How? Simply by pulling? I sure as heck don't want to break anything and have a $500 circuit board / panel to buy !
moparrh Sep 23, 2010 01:00 PM
Light bulb
Yes, they just pull off.
