2005 Town and Country V6 3.3L Start Up issue??
NEED HELP Start up issue I have a video but can't upload it, so in best detail of explaining it I have replaced the battery to being with but still having the same symptoms just a little easier to start it seems. When I put the key in and turn it over in P and no pressure applied to the brake it will only click once and the I have to turn it over again to only click once and no start. But if I put it in N or if I apply pressure to the brake and then turn the key over I get more clicking and then on try 2 or 3 with the pressure and then I can get it to fire up. What may be my problem? Thanks so much in advance for reading this and giving your input! |
Pressing the brake will have no function of starting the car. Putting it in N just bypasses the park natural safety switch. .
Remove the starter relay put a wire between 30 and 87 in the fuse box see if the starter spins over or the same single click is heard. |
Only got one click as well. Thank you for helping! Replaced the starter and it turns over just fine again! Hopefully this can help someone else too.
good deal
| All times are GMT -5. The time now is 05:17 AM. |
